Oil pressure light....again
(In Topic #166245)
Thanks,
Matt
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
my small block has a buzzer. Came on a few times when I had a leaky filler cap. Not sure where it is though.
sounds like you are having almost as many problems as me haha!
well the pressure gauge will go in when i have time and money to do it
Ive always wondered why i didnt have a buzzer, ill have a check on VAGCAT and see if i can find where it is
Yeah I know what you mean. Broke a temp sensor, the light flashed constantly. Would do my head in so I replaced it. Remove the light? Haha! All I can sensibly suggest is get a multimeter out and test everything. And make sure you 100% have the right sensors in the right places.
I am tempted to remove the light! haha
yeah i might give it a go but dont fancy taking my dash apart again
might ask rubjohnny what he thinks he seems to know everything!
check the connection to the cluster as well, make sure all the pins are nice and tight if any are loose carefully bend them up. check the pcb inside the clock plug as well can be a bit worn away by now or if the plastic housing has come off the plug can be a bit loose
In the garage so its not on the top of the to do list
Hows the engine after the head work mate?
Mine is actually coming from the seam to the right of my right rear light and has damaged my boot card slightly
Back onto the oil light, I haven't had time to check earths yet (hung over this weekend
The only issue ive found is that the LED strip i put in my clocks has warped the green tint strip
where would the issue be if it was a bad earth? and surely it would affect other aspects of the gauges?
the last one has a ribbon on the side of the white thing which looks like it has been cut or something
anyway well the original issue seems to be resolved which is great
But now i need to find why i dont have a buzzer, also these are the shape of the wires, which look strange
check closely at the pins inside your clock plug, make sure they are all poking out nicely from the plastic so as to make a good strong contact. check the blue foil in the plug hole as well make sure all the contact pads are good. oh and make sure the surround is in place around it, sometimes these go missing
you can remove the oil pressure circuit board its clipped inside the speedo, see if you can get another set of clocks the same make as yours, poverty spec without revo even be ok just as long as same make. plug in and try, if problem persists its the car, if not its your cluster. just make sure they're the same make as yours, if light goes away swap the oil pressure board over into your clocks and try again. if light comes on then its a deeper issue with cluster maybe the blue foil is worn at clock plug or has a broken track.
edit: also if the plug is a bit worn you can put a strip of card under the blue ribbon to pack it out a bit and make the plug connections a bit tighter
I will try and get it all apart and have a go at padding the connection like you said and if that doesn't work then ill try and get a new set of clocks, i might take it to somewhere where they can test oil pressure first too to double check but its definitely an electrical fault because of how erratic it was tonight!
Thanks John!
