Oil pressure light flashing
(In Topic #161758)
Ever since ive had my little 1.3 there was a wire that was grounded that i never thought should be to the engine block and next to it was a blue sensor with nothing connected to it. I was told the wire should be connected and i now know why it was grounded… just to turn the oil pressure light off -.- so either there is a problem or the switches are wired up wrong?
The blue switch has a blue and black wire and the green just a yellow wire, is this correct?
Cheers,
Matt
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
On my way to Uttoxeter coolant temp went right up, smoke came out of exhaust and wasnt running on all cylinders…
Maybe monday tuesday tho.
You going to sort the engine out or do a engine swap upgarde?
Matt
If you do repair it the bonus is you know it's right. You could swap for a polo gt and find issues down the line with the new engine.mazza411 said
Cheers, I know it just keeps getting worse! Don't know :/ I want something more modern but need the cheap insurance (I'm 17)
though looking at it 1 wire is grteen/black? if so not sure what thats for. some early mk1 only have 1 pressure switch btw
Ill put a
Although the head gasket problem is top of the priority if anyone can recommend any garages in mansfield/nottingham area that i might be able to limp it to?
Cheers,
Matt
rubjonny said
could be the 2 switches are the wrong way round, in a mk1 yellow is usually the low pressure switch and blue/black high pressure.
I believe its blue and black from looking at the wiring diagram, but could not find the solid yellow wire, is that just another pressure switch because the wiring diagram only says there's is only one oil pressure switch :s
is it on inj or carbs Simon?
your crisis may turn into a conversion mazza lol.
look again at madmatts picture, you'll note the yellow wire is going to a brown switch, thats the low oil pressure 0.3bar switch. the brown one is replaced by the blue one so swap that over
the blue/black wire is going to a white switch, this one is the 1.8bar high pressure. on yours you have a green one but I'm not sure what spec that is but if you undo it you can read the spec from the base. I'd assume though you'll want a 1.8bar switch, but sometimes the small block engines used a black switch 1.4bar (may have replaced the green one) also if the pressure switches are not genuine they could be any colour
as for the wiring very early mk1s are confusing in that the 2nd oil pressure switch wire didn't go via the fusebox, instead it runs to a spade and then direct to the dash clocks. the mfa oil temp instead runs via the fusebox. then on later mk1 the oil and pressure wires were swapped! 2nd pressure went via fusebox, temp went to a spade… and as i say, some early mk1s didnt have the 2nd pressure switch wire at all
On the wiring… thats very confusing but i will have a look thank you so much!
for example i beleive the polo gt lump has the same inlet manifold fitting as yours so it would drop rightin, with the exception of needing an electric fuel pump (or a late polo carb cam)
never used tgem myself see what they have you never know
Matt
