Oil light flashing
(In Topic #195334)
Help!!!!!
the oil light has been flashing but I have checked oil and all is good
today it was flashing as usual I turned the car off , then when I tried starting it it wouldn't turn over at all and the temp gauge also started flashing so I left it ten mins and then it started but oil light is still flashing what could this be ???? TIA
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
But it does run like a dog when cold
But this issue is separate to the issue with the oil light flashing. That can be cause by many things, wiring being faulty, or the pressure switch may have failed or in my case, there is an internal issue within my clocks and the light flashes whenever it fancies
The choke mechanism is a bit crappy quite stiff and doesn't really work as it should on mornings the car rarely starts with joke out it's always off basically and its a Webber carb
Whet would I find the pressure switch to change it to see if it is that
Im not entirely sure what the problem could be, does it run alright once up to temperature? and are the plugs looking a bit black? also, has it always been like this or has it suddenly changed?
On the back of the cylinder head at the top above the inlet manifold there are two sensors, one should be blue and one white i think,
Thanks for all the help!
