Oil in carb
(In Topic #108887)
Web Team
Oil in carb
The Car runs very well, but I have discovered oil is being drawn up into the airfilter/carb from the valve cover breather, and then dripping onto a hot inlet manifold. On reading up on the history of this car this has been a recurring problem.
Is there a mod. available, that you know of, to trap any oil but allow the vapour to breath into the filter, similar to that on the Saabs?. The engine has done 105,000.
Thanks.
Fit an oil catch tank like
http://cgi.ebay.co.uk/OIL-CATCH-TANK-ROUND-9MM-15MM-FITTINGS-BLUE_W0QQitemZ200320029185QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item200320029185&_trksid=p3286.c0.m14&_trkparms=72%3A1121|66%3A2|65%3A12|39%3A1|240%3A1318
May help . For a while .
Web Team
the breather pipe was smoking after i removed the air filter.
does any1 actually know the reason for this - i know its down to engine wear but what exactly - im currently rebuilding my engine and would hate to miss the chance to put this right with an easy fix.
cheers guys
logic said
its true that this must be a common problem - my 1.1 has a K&N filter fitted and after a couple of weeks the filter was really oilly :cry:
cheers guys
Cylinder bores are worn , gasses blow past the rings on the piston and pressurise the crank .
yes i meant that if the cylinder wall is oversized there is little you can do.
I thought usually the rings wear down and simply replacing these fixes the problem but your right getting the block honed and checked will at least show up any bore wear.
Cheers rusty
~Madferret
Mk1 1457cc 5door GX '83
