mk1 jetta starter problem?
(In Topic #157627)
the other day i went to start the jetta (1983 1.3) and the engine turned over…. no suspect noises nothing, but didnt start due to not being started for a while now so didnt suspect anything, left it for a couple of minutes and when i cam eback i turned the key and all the dash lights came on as per the norm but once the key was turned there was nothing! just a very slight whiring noise as if something was moving but was barely hearable. i tired and tried but nothing happened, i tryed wiggling wires and linking my other car up to it incase the battery wasnt up to the task etc, but still nothing. i then proceeded to remove the starter motor to bench test it, when linked up with jumper cables it seems to work as it should. so i cleaned connections and put it back in, still nothing…… any ideas? im stuck.
am i right in saying that there isnt a starter relay or anything stupidly obvious like that?
The isolator flange that sits between the carb and manifold had split. the engine cranked all day long but wouldnt fire for love nor money.
carb off, £15 part swapped and it fired into life 1st time, runs brill again now.
prob not related but that was my problem/solution
