Mk1 Golf 1100 Oil flowing out the dipstick tube
(In Topic #157425)
Oil flowing out of the dipstick tube
Matt
Last edit: by mattbibby
Cero said
Once you remove the breather itself you'll also need to check the hole in where the breather sits is clear all the way into the sump, this is normally is bunged up. Use a welding rod or stiff wire coat hanger to clear. Sounds like you've the wrong hose on there as the pipe should run to the air cleaner.
Hi, cheers for the reply. Removed breather and all seemed clean though a little crud came out when cleaned. When drained there was only about 2 litres in there so must have lost quite a bit. Have now put fresh oil in and this has stopped happening but it hasn't been run warm at all. So i think that problem is solved. However.. It is now only running on cylinders 1 and 4, have swaped/checked all plugs round and htc leads and has had new dizzy+arm. Have done a compression test just and compressions are 1: 12 bar 2: 8 bar 3: 12 bar and 4: 13 bar. My dad says 8 bar is ok to run but obviously it is low. Have had the head of and inspected valves and pistons/bore all looks fine structurally but cylinders 2+3 are very oily along with plugs. Head gasket is fine.
Should I next be looking at condenser, coil, points? Cheers
Matt
