Leaking sump
(In Topic #199700)
After finding the thread was damaged on the sump of my 1.3 CL I purchased a new sump, sump plug and washer from VW Heritage. Despite replacing all of these items, it is still leaking from the sump plug!!
Any ideas of what else I can do to stop it leaking?
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
I bought one from ebay (Vee Dub Machine) and there was a manufacturing fault with them as the sump plug would sit on a very slight angle so I could not seal the sump and oil would leak out, I got in contact with the seller and they found me a replacement.
Mine was on a big block car so not sure if it's the same sump?
The leaking one was made my OMG and I've now got a Febi one as a replacement.
I'll up load some pictures of the sort of angle the bolt was later tonight when I get home.
mark1gls said
What make is your new sump?
Now you mention it I think I remember the plug didn't quite sit flush against the sump (I assumed that's how it was meant to be) so that could well be the problem. Looks like I might have to source another or try one of the above suggestions
Pictures
Leaking OMG sump.
Angle of sump plug, as you can see it was only slight.
New Febi sump
you see the sump plug sits flat.
