help newbie
(In Topic #72922)
help newbie
1. theres a rubber mount for the carb. between the inlet and carb 1.1 gas i need a part no. to find new one :?
2. wiper problems i've got one speed and they do not park
tonto
1980 1.1 blue 5 door
Life Member
tonto
1983 1100 C
1983 1100 C
tonto
1983 1100 C
1983 1100 C
been working on the wipers now got two speeds and still no park (girl racer…dubbers)
tonto
1983 1100 C
1983 1100 C
tonto
1983 1100 C
1983 1100 C
I think it could be one of 2 things:
1) There will be a wire to the motor that is always positive (looking at wiring diagrams it could be black and grey?). Check this wire to make sure you're getting 12v when the wipers are switched off. The motor needs this 12v feed so that it can move the wipers to the parked position after the wipers are switched off.
2) It could be a fault with the wiper motor itself. It will have some sort of switch in it that cuts the power to it when the wipers come to the park position, this could be faulty.
So first check the wiring and then take the motor apart and have a look. You may need a new one.
I've never had a problem with mine on my golfs but have on a mini. I'm sure the setup is similar but may be wrong?
Hope this helps,
Ross
tonto
