help newbie
(In Topic #72922)
help newbie
Hi every one i'am new here just bought a mk1 golf got some problems can any one help?
1. theres a rubber mount for the carb. between the inlet and carb 1.1 gas i need a part no. to find new one :?
2. wiper problems i've got one speed and they do not park
tonto
tonto
1980 1.1 blue 5 door
Life Member
sorry you lost me :dontknow: what is the male version
tonto
tonto
Whats wrong with the rubber mount? Do you mean the rubber neck in the centre of the airbox that seals around the around the neck of carb? If so part number appears to be 052 129 625 B, but check at VW before ordering.
1983 1100 C
1983 1100 C
It's the one between the inlet manafold and carb .It's split
tonto
tonto
Ah, don't recall this being rubber? Think its a couple of cork gaskets usually, might be gasket sealent smeared round the edges that you can see? Sure you can still get a new carb mounting gasket kit from GSF.
1983 1100 C
1983 1100 C
The carb mount should be available from GSF or similar independent specialists. It's two bits of steel, with a rubber sandwich between them, to help prevent excessive heat transfer to the carb. The bottom piece of steel has four really long bolts (about 100mm) which go right through the inlet manifold. If yours is split, a new one will transform the engine, which is currently running on a really weak mixture (if it will run at all…).
Thanks to markwon and type17 got the carb mount ?14+vat.
been working on the wipers now got two speeds and still no park (girl racer…dubbers)
i think is an earth problem
tonto
tonto
Just to clarify, are your wipers on all the time when you have the car running regardless of the switch position? I assume you have a Golf C. The Golf C was the base spec model and VW skimped on intermitent wiper speed, so you will only have stop, on and slightly faster.
1983 1100 C
1983 1100 C
hi markwon i have fast,slow,off,rear they all turn on and off ok but the front will not park
tonto
tonto
tonto - not sure what you mean by park?
1983 1100 C
1983 1100 C
Park means when they are switched off they stop at the botton of the screen like normal!
I think it could be one of 2 things:
1) There will be a wire to the motor that is always positive (looking at wiring diagrams it could be black and grey?). Check this wire to make sure you're getting 12v when the wipers are switched off. The motor needs this 12v feed so that it can move the wipers to the parked position after the wipers are switched off.
2) It could be a fault with the wiper motor itself. It will have some sort of switch in it that cuts the power to it when the wipers come to the park position, this could be faulty.
So first check the wiring and then take the motor apart and have a look. You may need a new one.
I've never had a problem with mine on my golfs but have on a mini. I'm sure the setup is similar but may be wrong?
Hope this helps,
Ross
Hope this helps,
Ross
Thanks to every one got it fixed..The wipers work without the relay but don't park the relay switches the earth/neg to make them park..problem solved duff relay
tonto
tonto
