HELP!!! CARB ICING
(In Topic #72989)
HELP!!! CARB ICING
I currently have a MK1 golf C (1.1) and have recently fitted a weber conversion carb and KN bolt on filter and am now having trouble with carb icing.
The problem being i have misplaced the original air filter!! DOH!!
Anyone know how to cure this problem or know where i can find an original air filter housing for a MK1 1100
Cheers!!
1983 1100 C
1983 1100 C
How much difference in performance did you notice with the k&n bolt on? do you have a photo? where did you buy it from?
cheers.
'83 Mars Red 1.1 C
Mk1 VW Golf 'c' restoration job....
Life Member
I had to give up with the bolt on air filter as there is no way to give it a warm feed, summer only option! There was a reason VW used the 'frying pan'.
If you go back to the frying pan, on the 1100 it's also worth checking the condition of the preheating cover that goes over the exhaust manifold, most are rusted to bits and so not much warmth goes up the warm air feed
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
1272 driver with a magic tree!!
