Hello
(In Topic #73191)
Hello
Life Member
Welcome to the site. Quite a few of us around and about in Kent! I live near Ashford.
The car doesn't sound bad at all, it probably just needs a tune and some tweaking to worn parts. The Formel E engine is a little more tricky than some of the others, but not beyond the capabilities of people on this forum to help. I'll move this post to the small engine section so it gets seen by the right people.
I can recommend a mk1 friendly garage in Canterbury though, a number of us go there and have been made welcome with good service.
Volksline 226 Broad Oak Road, Canterbury CT2 7PX
Dial 01227 767958 and ask for Ian.
Make sure you say you got the info from the Mk1 Golf Owners' Club.
Best of luck,
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
…….another from Kent.
I would say that if the body shell is good with no serious rust it's worth spending a bit to replace worn out mechanical bits (suspension, brakes etc). You don't have to pay an arm and a leg, I'm sure I have seen ads for VW specialist places based near you, and you have GS&F (German, Swedish & French) at Thurrock, and others for reasonably priced parts. As Drew says, we use Volksline in Canterbury, who although being just down the road from the main VAG Dealer, are MUCH cheaper (and friendlier).
The gear change could very well (at that mileage) be just the linkage bushes - about ?5 for the bits. It could be the synchros, but I've learnt to live with it on the GTI - it's the way you drive it !!!!
The clutch can be heavy, but I found that a new cable sorted out my
old 'Faithful'
and the GTI.
If the engine smokes (and smells) it's usually the valve seals - again quite cheap to cure.
As long as the engine does not 'rattle' it should go on for ever !!
Good luck
1983 1100 C
1983 1100 C
You probably need new engine mounts at that mileage, which will improve the gear-changes, but also check the condition of the gear-shift linkage.
If you are finding the clutch very heavy, try fitting a Golf Mk2 1.3 clutch cable - an improved design and different route around the back of the engine means that the pedal feels a lot lighter.
