Fuel issues weber carb
(In Topic #153938)
My 1.3 with a weber 34ich carb is not running right!
It is often hard to start when cold, and then needs choke to stay going. On acceleration, it would sound as if she is missing, which is helped by adding more choke. When going at a steady speed, she is slightly juddery. All of this is emphasised when the choke is in, providing the engine doesn't stall.
I have set the ignition timing, and ordered some new plugs, bosch w7dc as per the Haynes manual.
I removed the carb, and have stripped most of it down. None of the jets were obviously blocked.
Any ideas? And approx, what jets should I be running, so can check to see if it is right.
Should I get a rebuild kit for the carb for 20 quid to replace all the gaskets, seals and diaphragms although they look ok? Or would it be wasting my money?
Rob
r_chez_08 said
Hi,
Rob
Different engine, same problem though- mine 'solved' by a clean of the carb, setup and flushing the pipes through following replacing the tank. Highly frustrating and think it was a combo of the issues- crud from the tank blocking the lines, getting in the carb and a vicious circle eventually leaving the car only running when the choke was out. Think this was the case as it was forcing more mixture into a clogged carb.
Apparently the jets etc were fine in the carb but after a bow out with the airline it seems (fingers crossed) to be working, the first time since I picked it up.
I boiled up the carb body and jets in citric acid solution, used to do this on my kart carbs, and it works a treat. Everything should be okay so ill reassemble the carb tomorrow.
How can I check to see if the tank is full of crud? And surely the filter would stop it getting to the carb?
Rob
When i took mine apart i used loads of carb cleaner and the air line on low. Its great to see what you get out of it lol
I reassembled the carb today, installed with a new gasket. Realised I set the timing with the vac advance on, so I took it off and re timed. Started up with no throttle and a little choke, turned the mixture screw out about 3 turns, runs pretty good! Idles around 700, sounds slightly lumpy, but not too bad. No smoke coming out of the exhaust which is a plus. There is still a slight miss when revved up, around 1000 rpm, but not as bad.
Ill take it for a run and see
Edit: if you floor it, there is a slight jump/ delay, and if you rev up really slowly, it struggles slightly going from about 1500 rpm to 1800 rpm. Then again around 2500 rpm. It would stall out if you revved really slowly over 1500rpm, but I richened the mixture with the screw, and it doesn't stall now, still a little hesitation though.
All of the above is remedied if the choke is pulled out about 2-3mm, level with the dash, which makes me think that the mid range needs richening, as idle is fine, and same with top end, but with the mixture screw richened enough to stop the stalling, the idle is a little smoky- splattered black marks all over the drive!
Is there a jet to richen mid range that I could drill out?
Edit2: pics
Last edit: by r_chez_08
The fuel lines were quite perished at the ends, connecting to where the sender goes in, but chopped 1/2" of both ends and there not too bad. I'll probably replace them anyway for good measure.
This is really daffodil me off now. I am 17 in a week and a half and want to start driving. The plan was to drive her round the farm, so I got some practice in before I was 17, so much for that! Might just take her to a garage (please persuade me not to!!!!! Quitter!!!)
But when I will be driving her 45 miles a day, she needs to be right.
Oh and another thing- the oil light and buzzer came on whilst driving, the level is fine (actually slightly high) and the gauge was sitting at around 4-5 bar.
WTH is going on?!
Made an order with GSF. new gasket for intake and exhaust manifolds, new fuel lines coming off the sender, new rocker cover gasket and oil cap, as there was a small leak from there, the seal was missing. I may drain the tank, and put new petrol in, it may just be old fuel? Then I'll try blowing the fuel lines through. Cant think of anything else. Really confused cos she ran really quite well, so doesnt seem like a jetting issue!
If anyone has any ideas, that would be amazing
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=small-block-carb-engines_2%2Fweber-34ich-tech-sheet
Rob
Gordonthegolfer said
is it between 2600RPM and 3100RPM by any chance?
Maybe, why?
Chris
http://www.vwheritage.com/vw_spares_Ignition-Leads-Set-Mk1-056998031_act_shop.product_pID_55911105_lang_EN_country_GB.htm
They are bremi's and say '51 ohm' on the cap.
Just did a compression test. Forgot you had to do it warm. Got just over 50psi per cylinder, so I would presume its OK as they are all uniform? Therefore no valve issues thank god! I wouldnt trust the calibration too much tho, it was a cheap POS compression tester!!
The only thing is that you still need to give it a little choke. Tried richening the mixture screw by 1/4 turn and it ran worse. Any ideas? Oh and she doesnt start as well as she should when warm.
