Electronic ignition for 1.3 driver
(In Topic #115953)
What doesn't kill me can only make me stronger.
Mk1 will be back.
Mk1 will be back.
I bought it for my son's Driver - fitted it in late July - made a big difference to starting and general running - also added about 4mpg instantly
Not cheap, but worthwhile
Slightly fiddly to fit the gubbins into the distributor - actually, that's not true - its a doddle to fit, but its a bit fiddly making sure the wires don't touch the optical chopper when the vacuum advance is activated.
Mk1 will be back.
Mk1 will be back.
You should call them
Grant25 said
wow very clever what you did there…
I thought so - glad to be of assistance
You need Optronic fitting kit FK217 for the Bosch dizzy - about ?18 on top of the ?160 - ?180 for the ignition module (RRP is ?195, but you can usually get a bit of a discount)
\'79 Golf.
\'83 924.
\'91 Golf.
\'83 924.
\'91 Golf.
ed5000 said
Would the same kit be suitable for a '79 1.1?
Almost certainly (but check before you part with your money)
The Lumenition application list says:
Bosch 0231-186- 009/015/017/023/024/037/038 with top
bearing plate (screws to internal circlip) - NOT 0231-191
onwards
So - as long as the 1.1 dizzy is in the list above, it should work just fine
\'79 Golf.
\'83 924.
\'91 Golf.
\'83 924.
\'91 Golf.
