dwell angle
dwell angle
Hey, How do you set the dwell angle accurately on a 1.3 engine?
Can't believe with contact less ignition kits so cheap you are still using points ?
  :D
ive got an ampmetre with dwell.  How do you adjust the angle?
The dwell is a degree measurement of the points gap . More accurate than using feeler guages .
http://www.gunson.co.uk/items/pdf/Technical/G4070_Autoranger_Instructions.pdf
You can download instructions ………..
ive put the metre on the motor and its reading 65.  The manual says it should be between 45 - 50.  how do i decress the measured number?
Increase the points gap reduces the dwell
Decrease the points gap increases the dwell
So you need too reduce the points gap
Cheers…………………
