dodgy dizzy ?
(In Topic #134367)
dodgy dizzy ?
car started running rough so put it down to needing a service replaced everything and am having trouble getting it to run.
now i have fitted electronic points but to get it to run it needs the timing advanced way too much and the same goes for if i have the standard points in.
ive taken the distributor off the car and have noticed a fair bit of play in the shaft/spindle …. have heard of other cars having similar problems with play and they have had to have a new distributor … was just wondering if the movement is normal on a 1.1 golf ?
thanks !
thanks !
Pretty much got the same problem with my 1.1 so any replies would be really helpful for me too!!
probs no help but if its a formel e are you running it on the 'good fuel' super octane or whatever it is. and if you are have you set the timing to a standard 1.1s setting!? i filled up from BP the otherday with their super octane and my car stalled at every junction until its had run through the tank,and now its totally fine again
probs no help but though i would try!
si
si
