Belt Teeth
(In Topic #105220)
Belt Teeth
Purchased the belt & pump without problem. When going to fit i noticed the teeth are different. The teeth on my existing belt/pump seem more shallow and square so I contacted my supplier who tells me i def have the correct parts for my FA engine code?
Thought I would go genuine instead but the part number for the belt is the same as an later polo 1.3 NZ engine. I have one of these engines spares and the pulley teeth are def different.
Presuming this means there interchangable?
novocaine said
is the water pump run off the timing belt on an 1100?
yep
Thanks for the response also Cero. So guess im ok to use then though different
