Accelerator Pedal "Sticking"
(In Topic #166045)
un-intentional cruise control on my Driver
I am having an intermittent problem with my accelerator pedal getting stuck down ever so slightly, enough to maintain a steady speed in whatever gear. I can flick the pedal back up with my foot and it stops it but it can make me sound a terrible driver when changing gear and the car revs without intention!
I have read that it can be a cable problem…but i have no idea what to do to sort it, any help would be great!
Many Thanks
Toby
Thanks for all your help guys
as for fitting its a case of unhook from accellerator pedal, pull it out the bulkhead, disconnect from carb and refit the new one the same way old one came off! before you start though cvheck both ends of the new cable are the same as the old one
when adjusting set it so that when pedal is flat to the floor, the throttle is just at wide open (i.e. you cant pull it open any further by hand
oh and while you're under the dash check the throttle pedal isnt bent, it should pull the cable in a straight line thru the hole in the bulkhead. if the cable is set too tight it will bend and eventually end up pulling the cable at an angle which leads to it being damaged and becoming sticky.
1985 Cabriolet GL
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
