A bit worried and annoyed!
(In Topic #81186)
my car seems to just cut out at junctions and when i stop etc. it doesnt even tick over for a short amount of time, seems to be as soon as i put my foot on the clutch and stop. It used to do it now and again but now its realllllyyyy bad and does it pretty much every time! grrr its getting very annoying.
1980 1600 GTI, daily driver.
Anyone?
had this on my polo, may be the mixture or timing.
and LOL at " injection only " knowledge !!! 8O
Real golfers don't play with clubs
if it doesnt get any better have a look at ignition - coil, condensor, dizzy, rotor arm, leads, plugs etc. theyre all cheap and improved my car loads
Greg 8)
1981 Golf C 1.1
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
I presume you are rumming on the standard Solex carburettor ?
If you pull the choke out, does that stop it stalling ?
If it has got worse recently I suspect it's electrical rather than fuel.
Do you have a local friendly garage who might help with the diagnosis ?
Greg is right they can be little devils, the golden rule is to be methodical and work from the basics. I have just fixed a similar situation on one of my 1.1s which I was convinced was the carburettor - turned out to be the points.
Check the plugs - what colour are they ? set the gap or replace.
New points and reset the gap/dwell angle.
New Condenser.
New Rotor arm.
New Distributor cap.
All cheap from Partco or GSF.
After this try renewing the HT leads and remember the one from the coil too !
Post back and let us know how you're getting on.
If there is a split in that, then the engine is sucking in air after the carb, so is not getting enough fuel.
Had this prob on mine when it was 1.3. took bloody ages to find too!
My Build Thread
AL_Mk1 said
Check the rubber mount between the carb and the manifold (Use a torch, remove filter housing and rock the carb back and fourth with your hand).
aL BEAT ME TO IT- THIS IS WHAT MY 1.3 USED TO DO! youd be driving along quite happily then put your clutch in to stop at a junction and it wuold just stall. Heres my understanding of it.
as your putting your clutch in, there isnt as much load on the engine, therefore it doesnt need as much fuel, so as everything slows down, if the carb gasket is split, it opens up as the carb moves about,but takes in more air, resulting in a weak/almost non existant fuel mixture. so it stops. pulling the choke out will help obviously as it is creating a richer mixture so the air isnt "diluting" it as much.
i know its a sketchy explanation but can yuo see where im coming from!?!?
Please don't call me fella- its deeply insulting to one whom is no such thing!
new plugs and leads and points it ran fine after this untill about 2 weeks ago.
