1.1 bike carbs
(In Topic #121253)
1.1 bike carbs
Has anyone got any info or know of anyone who has run a 1.1 on individual bike carbs???
Don\'t hate the player . . .
i think its gonna be a bit of trial an error
im still gonna have a go tho
booze and boredom, the greatest mix
apparently you need to work out how much power you want and then look on a bike with that amount of power… or summat
trial and error for me all the way hehe…
What cam is suitable for the 1.1 engine? (engine code FA) Any suggestions? Will get a custom exhaust manifold made as well.
and let us know about power and economy.
i was gonna get a cheapy manifold made up by Phataz1 on here but i found some plate and now its half done, just looking for the CHEAPEST possible carbs as im proper skint
i wanted to know cam stuff too so hopefully someone will run over this and be able to tell us. no one seems to do anything for the 1.1…
does anyone know if there is a diffrence in the 1.1 and 1.3 cams?
heres a little list of all the early factory camshafts for the mech head, giving inlet and exhaust durations . hope you guys find this useful and good luck with the project.
Rusty Hookers Dub Club
thanks again mate.
just need a balancing kit now
as for the jets i think im going to go a little at a time, once i got it running roughly right ill order the correct jets so there all nice and new. ill post some pics when the carbs arrive.
i thought the jets would be .95 but after cleaning out the bowels of them as they were old i found they put 117 jets in, im thinking this should be ok…
might run a little lean under full throttle but i got a colourtune and i will have a balancing kit soon too so i should be able to set them up just right.
my mates dropping the tubing over to mine at 5 and im cutting them and welding them onto the manifold i made so all i gotta do now is drill the holes for the bolts and make some spacers for them too.
then find the rubber…
im thinking ebay again
ill make a walkthrough when im done so everyone can see how its done.
right gotta go, mates here with the pipe
cheeers!
friday im doing all the welding… ill start the walk through tomorrow night as i got a few pics of carbs and stuff, i also found a set of carb rubbers from an old bike in the garage so i dont need to hunt for silicone hose over the bank holiday.
all being good i should have her running by friday night…
im a little worried about the fuel issue tho cos theres no return on the carbs as the bike had no fuel pump. so if the fuel lifter pump goes a bit over the top i might end up with an over flow problem. more hose on the overflows should sort this if worst comes to the worst tho. got my exits covered
cant wait till friday!!!
but not good enough, i need a fuel regulator and im gonna be waiting a while for one off ebay but none the less, i took it round the block… sounds nasty
i cant wait to get it running proper. ill get some pics up on my mods page
link here
i left my cam in the garage and my knees are killin from being over the eingine bay all day so im not goin back in there yet…
performance wise… hmmm, i had the advance hose off but i did advance the timing, once high in the revs it went better and more response.
low down its sluggish but i did have the vac hoses off. i took a tube off inlet 1 and used that for the servo so that works all good
i was thinking the jetting was wrong but the carbs need balancing AND idol needs doing. fuels pissing out everywhere so iv put the standard carb back on till i get the fuel regulator.
WATCH THIS SPACE!!!
iirc you could achieve this with a filter king or similar??
Jon.
i was looking at this, thought it would look cool unsder the bay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120542378427&ssPageName=STRK:MEWAX:IT
never seen a swerl pot before, i got some googling to do me thinks
so if im right its like a pot… lol
it has an in, out and return. when the bowles of the carbs are full from the gravity feed the pressure just goes down the return pipe. seems a cheaper way of doing it
ill get on it tomorrow.
thanks Crowson
cheeers!
they look like this
http://cgi.ebay.co.uk/…ts_SM?hash=item20b016a6c2
but have an in pipe and a return pipe at the top, and and the feed pipe at the bottom!!
only the ones i looked at appeared to have clips so you can keep them mounted upright.
Jon.
