Who has 13's with 16v brakes?
(In Topic #97344)
DubPartz
hello!
im running 13x7 ats classics et 20 no spacers
ive got auii coupe brakes on the front 239 x 20
ive had to clean up the castings on the caliper so the caliper des not rub with new pads
with new pads in, the caliper is about 1mm away from the spokes of the wheel, and there is about 3mm between the front of the caliper and the inside of the rim
hope this helps
Re: Who has 13's with 16v brakes?
Nick205 said
If anyone is running 16v discs and calipers under 13's then what wheels are you using?
do you mean 16v 256's?no chance,240's with venteds and vw II's yes including rear disc assembly. Depending on wheels you may need to take a nick out of the face of the front calipers but you can run mk2 rears under 9 spokes :wink:
Admitedly a little bit of shaving and 20mm spacers but it is possible.
