wheel resto advice
(In Topic #88330)
wheel resto advice
want to polish the rims deep dish and paint the spokes black
whats needed oh and i dont have a blaster
A lot of sandpaper, from 60 grit to 1200 grit, if you dont have a lot of pits in the aluminum you could start with a higher grit.
Some polishing wax and polishing wheel to mount on your drill.
After a lot of hours, it will look something like this:
Before:
I have a set of VW option ATS Cups that need similar fettling.
DubPartz
vw_tees
very nice BTW
foxymk1 said
how many hours per wheel?
very nice BTW
Thanks..
I don't remember, but I think I did them in two weeks.
An hour or two in the week days, took the weekend off
The sanding is pretty boring, but when you get to the polishing bit and you see the result it's all worth it….
Here you can see what it looked like when I was finished sanding:
After polishing, before wiping off the polishing compound:
foxymk1 said
did you sand them by hand?
I did most of the sanding by hand, but where it was deep pittings in the aluminum I used an air tool with a sanding wheel on.
Like the one at the right in the picture.
