Wheel question - width/tyre offset question
(In Topic #137569)
I'm looking to fit these to a standard (externally) mk1 gti but just wanted to know before buying whether the offsets etc are right.
Also would the slight difference in width between the front and back set be noticable?
1 last thing, what tyre size would be recommended for these? Current alloys have really good 195/45/r15 conti's fitted so would be nice to use those. Although it does have a 20v turbo fitted so any extra width/traction would be useful!
thanks in advance
To give you a heads up 38ET is the standard offset. the lower the number the more they will stick out, the higher the more they will sit back in the arch.
7" and 7.5" will look sweet if u can stop them scraping.
I guess I could get the arches rolled as well. It's not massively low so that will help.
Tyrewise I don't mind getting some new rubber. I was just curious what profile and width I should be looking at
et15 Hmmmmm depends if you run low, I wouldn't rock such an offset myself.
