vw caddy lowering springs
(In Topic #73474)
Hey just wondering if anyone can tell me how to lower the rear end of a mk1 caddy pick up? do i need new leaf springs? if so where can i get them? thanks Daz
caddy
hi your rear beam/axle is mounted below your leafsprings u need to remove beam cut mounting saddles from top of beam and re weld them to bottom of beam then u can mount beam on top of springs job done
Daz - Join up on the Caddy forum (http://www.vwcaddyforum.com/). Loads of info there (I'm on under the same user name - m6m62). What 3piece says is correct though.
Cheers,
Mark
Cheers,
Mark
You also need shorter shocks when flipping the axle,most use beetle shocks (early 60's I think) which are very cheap from eurocarparts but I think FK etc also make proper shocks for lowered caddys.
Caddyforum will give you all the knowledge you'll need
Mark
My cars -
72 Moonraker - http://www.volkszone.c…i/showthread.php?t=304603
MYSPACE
My cars -
http://dubforce.net/pi…files/webfiles/Rallye.htm72 Moonraker - http://www.volkszone.c…i/showthread.php?t=304603
MYSPACE
have present caddy on standard shocks and 1 before also not had any probs and had it loaded up have fully adjust/coilovers on front u pays ya money and take your choice
