tyre pressure
(In Topic #110226)
tyre pressure
hi guys
anyone know what the right pressure is for 195/50h15, im running them on 32 at the min but they just dont feel right, they squeal when going round corners like there flat, greatful if anyone knows.
Tyre pressure doesn't make any difference to tyre noise - that's mainly governed by the kind of rubber compound (the softer, the less squeal you get). I'd say stick to stock initially, but a little lower in proportion to how much wider over stock, would be okay. Make sure the rears are not too low too. Basically, the lower the pressure, the better grip, but faster wear and more possibility of coming off the rim. And once you reach a certain pressure, the tyre becomes unevenly deformed and will wear its edges (or middle if overinflated).
so is 32 ok? thats what mine are on, if i go any lower the steering is so stiff?
Well the standard pressures are something like 26 and 29. So 32 is a little high but still acceptable, if you like your steering light.
cheers chick
My tyres squeeled round the slightest corner when my tracking was out (after fitting different suspension). Just a thought, if different pressure doesn't cure it.
cheers guys
should have checked the tread first, just been to get them replaced both front's were bold on the inner side, needed trackin as well they say it was well out of line, but all should be good now thanks anyway chaps.
