toledo engine
(In Topic #106180)
toledo engine
ive seen a nice toledo for sale but im unsure of the seat set-up. so i guess what i wanna know is does this car have all nec. parts to fit in mk1 golf gti 1600 (im aware i have to change an engine mount, not sure which tho)
and would this conversion require any specialist work or customisation?
any help appreciated
andy
looks tidy with colour-coded bumpers and front fogs if this helps??
andy
I'd say if you already have the Toledo, go for it, otherwise don't buy that car simply for its engine conversion. There would be plenty of other parts you'd need too (the Toledo, by no means carries all the parts you'd need) and with the extra cost and effort in sorting these out (ECU, manifold, cam, various bits & bobs) you may as well invest in a little more, and go for something which will gain you a much bigger % increase in power.
Of course, thats just my opinion, someone else may come along and say something completely different!
the toledo has gone now so were lookin for another donor car, what would you suggest? will more than likely be changing everything inc loom etc.
also lookin at puttin discs on the rear, am i right in thiunking that the mk2 stub axels fit on the mk1 axel??
thanks again, very helpfull
andy
Pyrotechnix said
i see what your sayin, its gonna be an ongoing project so eventually itll be maxed any way. i think 16v is gonna be the prefrance atm, more tuneable and obvious advantages…
andy
Its the same as anyone else, how much money do you have, what performance level do you want, what's the intended use of the car (daily driver, occasional road use, track days?), what skills and tools do you have, etc
car will be use daily and occ on track.. need to do some searchin me thinks!!
andy
will the mk2 stubs fit the mk1 axel?
andy
and rear brakes too??
andy
For that money, probably 3A bottom end, giving a 2 litre 8V? Getting hard to find that engine tho.
the rear brakes are drums and wanna put discs all round, wanna know it will stop well!! lol
so you recon pb engine? they have digi injection too, no more k-jet antics allowed! what are g/box options t suit the car? standard 02a/j?
andy
Use your standard gearbox too, no real advantage in going to 02A (and the 2E in the Mk3 Golf GTI uses an 020 anyway??)
andy
