Suspention question!
(In Topic #144847)
This could be a real silly question to ask but I'm looking into an air ride system and found a company that I like the look of trouble is the don't do mk1 air the closest they do is mk2, I was wondering would you be able to install this system without too much trouble?
Cheers all
Jordan
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
1989 MK1 Golf Clipper
1999 Ford Cougar 2.5 v6 (soon the nightmare will be over and car gone)
Self levelling full on air job from the likes of plush automotive will be around 2k+
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
89clipper said
I dont wish to hijack your thread but what are the advantages of air ride?![]()
Is that a rhetorical question?
With AirRide the system combines the use of shock absorbers with air bags to manage the comfort, handling and height of a cars ride. The air bags can be inflated or deflated to adjust the ride height of the car, at the flick of a switch or press of a button.
AirRide allows you to pick the perfect height for your vehicle in any circumstance and allows you to lower and raise the ride height of your car as needed, whether parked or driving.
On a Mk1 Golf, the front suspension geometry means that at differnt heights, the tracking will be different. So only at one particular ride height will the tracking be correct, at other heights (give or take a few mm) it will be too far out to drive on, resulting in unusual handling and massive tyre wear.
The main advantage is you can drive it at a sensible height, but then lower it once you are parked, for a 'look'. Of course, there's other advantages such as load capacity, towing etc but that's kinda lost on a mk1 Golf.
