stiff gear stick
(In Topic #77558)
stiff gear stick
Welcome by the way, see this is your first post - tell us a bit about yourself, what Golf do you have?
Each year I clean the linkage on mine with white spirit and a paint brush, then use spray greese , the type used on motorbike chains ,this improves the gear change a lot.
Ali
Got a Golf C, getting into 1st gear is a total nightmare, im not just being a wuss, because the gear level is almost bending with the force needed to get it to engage sometimes
Any ideas?? Bushes maybe, what should I look for?
11/1300 gearboxes have a much simpler selection mechs with very few bushes to replace.
Only ?30 so I hope this fixes the problem
The clutch cable was coming through the bulkhead so with some help from my buddies, we were able to make an aluminium plate to go across and stop this happeining.
Its super smooth now!
