Steering Column Top Bearing Question
(In Topic #116141)
Hope this isn't TOO much of a stupid question, and if I'm wrong, where do I get a new top bearing for the steering column?
Cheers.
you will need the small plastic bush - this slips over the steering column and then the ignition unit is pushed on next and the small plastic bush locates the bearing on the shaft
the original bush will be completly knackered therefore allowing play in the steering column
its only pence from vw if i recall
191 419 341 - 1.16+VAT
however since its a later car it will have the spline adaptor on it, which can be a bit of a mare to remove
worth trying to nip up the allen bolt that holds the lock housing to the outer column, this can sometimes work loose and give you this play. You should be able to access it thru a hole in the lock surround
