Standard front springs.
(In Topic #72654)
Ideally I'm thinking some new standard springs(pair) new shocks and new top mounts.
Only thing is GSF only list mk1 springs, not GTI springs, and VW want ?50 each for springs!
1. so any one know where I can get cheap GTI front springs?
2 I have been told to get original VW top mounts as GSF ones wear out quick, anyone know about this?
Peter.
1980 1600 GTI, daily driver.
cheaper than the ?100 VW want for two.
Big boys toys think they can get them. ?17.50, but none in stock!
Gonna lower my car at this rate!
Peter
I've recently replaced my front shocks and top mounts and asked for advise here too, this is what I found out:
Springs: Genuine ones have spots of paint on according to model, I found out through ETOS and littlekev that mine were correct.
Inserts: I uprated mine to Boge gas ones from GSF and ride is much firmer and not really any harsher (my old ones were Monroe and were past it anyway). LittleKev has gone for genuine struts and inserts. I'm sure he said that inserts come with new struts and the price was only a few ? more that the Gas inserts I bought from GSF. Wish I'd known before really!
He said that the inserts are the same for all golfs now as only the heavy duty ones are now available which were originally used for the GTI.
Top Mounts: I took Dubboy's advise and went for Febi ones from GSF which he said should be fine (they had the original part number on). GSF also sell a kit for top mounts which includes new bumpstops, bumpstop cups and metal sleeves/bushes that go inside the top mount. The parts in the kit didnt look like they were going to last so long but GSF assured me they were as good quality as Febi parts, I wasn't so sure so didnt go for the kit. I bought genuine bumpstops and cups and new sleeves and some new washers too.
I was going to do a how to on replacing front shocks but havent got round to it yet. I've got some nice pics of what happens to the top mount bearings and the top of the inserts if the spacer is left out!
What's a strut?
Peter.
Re: Standard front springs.
tallpete said
The previous owner has somehow got the right side 20mm higher than the left. Doh.
Did the old owner live in Milton Keynes?? …all those roundabouts!
Called them, they don't do any springs at all.
Can I use second hand springs with new shocks and top mounts? or is that a rubbish idea.
Still not sure what struts are Ross.
Peter.
171411105G951 or 171411105G953
Might sound hard to belive but some polo's from 90-94 were fitted with the same spring????
Both are priced at ?40.94 & vat and have blue paint marks
1996 Gti Anniversary 8v Mystic Blue
1995 Gti 16v Fjord blue
Top Mount - Rubbery thing at top, Get Febi ones from GSF ?10ish
Springs - ?50 from VW or Second hand??
shocks - Ross called inserts? VW ?30 or GSF ?20
Strut- Don't know, how much? where does it go? do I need to replace? Included in VW price?
Peter.
http://www.courtesypar…32/oe_shock-front_tt.html
The part that has the description front drivers side/front passenger side is the suspension strut. The strut on the golf has a removable 'insert' which can be removed from the strut after unscrewing the large cap on the top of the strut. VW dont sell inserts separately as far as I know but GSF do and sell uprated gas ones as well as standard oil ones.
If I was going to change my front suspension again, I'd go for VW items as its much easier to replace strut and insert as a complete item. It can be difficult removing the insert from the strut as the cap holding the insert in can be a rusted on badly.
Hope this clarifies?
Guest user
171412031J Frt strut ?31 & vat (includes shock absorber)
171411105G951 Frt gti coilspring ?40.94
Vw have never done inserts, they just supply the complete strut. I wouldn't waste my time with an insert either unless i was upgrading my shocks in which case i think you can only buy inserts.
I could sell the genuine struts for ?24 & vat but unfortunately the carraige would bump the price back up
Just ordered 2 springs, two shocks, and two top mounts. ?200.
Gulp.
Peter.
suspension
Am I right in believing that Cabrio springs are 20mm shorter than standard Mk1 Gti springs?
I believe the original Struts & dampers were supplied by Bilstein and the replacements are B4,s which bring the handling back to original with a 5% improvement - whatever that means. I dont know who manufactured the springs but Eisbach seem to make the correct approved ones.
Anybody found a good cheap source for these parts please let me know.
1983 1100 C
1983 1100 C
