Spongy brakes after new brake parts.
(In Topic #137259)
Fully flushed out system with new fluid.
No leaks in any joints.
Used pressurised ezy bleed and 1 way bleed hoses on nipples.
Also tried 2nd person working brake pedal.
Cable tied fully open the rear compensator valve.
No more air coming out of bleed nipples.
Servo and MC in good condition.
Bleed rear right, rear left, front right then front left brakes.
But still got a spongy pedal, which is worse when the engine/servo is on.
Any advice guys?
Cheers skid.
Would be pretty hard to put them the wrong way round as the hoses wouldnt fit and be kinked
Any more thoughts guys?
Does the servo or master cyclinder need to be bled?
Very shocked as i took the car out for a test run last night and it was taking ages for the car to stop.
I fitted black diamond discs and pads and thought they would bed in quite quickly abviously not :?
I will just have to get round to fitting my upgraded servo and MC soon…….once i figure out how to get a brake switch fitted.
The vacum feed was never removed anyway.
