Speedo gears
(In Topic #72841)
Life Member
My Build Thread
prob no use to u but thats all i know :roll:
Life Member
Go on the motorway and drive at 79mph - if everyone is overtaking you your speed is probably right! Follow some trucks also as they are normally limited to 56mph so a good ballpark also. If you find a white van drive 2 inches from thier bumper (note correct spelling tallpete - betrter aftir a fiew bears) and check your speedo - if you are doing >89 mph, again speedo is correct.
For low speed calibration find some sort of wierd suzuki or matia or other eastern/indonesian make with one or two occupants who look a little elderly - also worth checking if they are local (use registration code) - and follow them in a 30mph zone - they will be either doing 40 (because they drive at 40 everywhere) or doing 18 to 20 mph (easy to work out 40 vs 20) and calibrate from that…
Hope this helps…not sure if it would stand up in a court of law!
Life Member
http://www.nwlink.com/~vdb/vw/Transmission/speed-ratio.html
As long as you know the code of your gearbox, (or if you know all of the drive ratios) this will help.
Enter your tire size, the FD ratio then the gear, say 5th ratio. enter an RPM figure, say 3000 and it will tell you how fast you would be going.
Works great - assuming you got a working rev counter in the car.
I used this to produce a table of speeds at certain RPMs in a range of gears to test my speedo calibration.
AL.
My Build Thread
