Speedo cable/gear box
(In Topic #134241)
I've just bought a mk1 Caddy with a 1.6 driver and 4 speed box.
After buying it i realised the speedo wasn't working. Upon checking the cable was knackered so bought a new ne from GSF and tried fitting it last night.
I've not done anything with these engines before and am not a mechanic…. The old one came out fine, probably as the bolt wasn't tight and i don't think its the right one.
Should the end of the speedo cable that goes into the gear box actually locate into something? There doesn't seen to be anything inside that it sits in. The only thing i can feel inside is a threaded shaft which is to the front.
Any help/ideas would be greatly appreciated…. Theres too many speed cameras around to not have a working speedo!
Matt
Looks like im missing the part that clips to it and has a cog on. I'll have to check to see if its floating around in there to make sure it doesn't do any damage…
its chep from vw if the old cable doesnt have it. then once the gear is fitted its a case of drop it in then wiggle it around till the nipple on the end of the gear locates into the hole in the bottom of the gearbox casting. its fiddly!
Thanks for the help
I'll put the code on here once I've done it.
Might not be today tho as I'm a bit delicate after crashing my bike and breaking a rib!
