small block 1.3 carb, any 5 speed box's?
(In Topic #121569)
are there any boxs that are a stright fit with 5 gears?
i was thinking a polo box mabey a mk2 polo coupe s 5 speed might fit?
they fit easily, just need the front mounting's joining together!
the original has three bolts into the box, the 5 speed has two bolts on the side. makes sense when you see it.
you may need to remove one of the rubber pads off the gearlever cage inside the car to allow the lever to travel far enough over to the right.
Jon.
Jon.
