Rear wheel bearing issues
(In Topic #104233)
Right well my rear wheel bearing collapsed on me on my clipper, so got a vag bearing kit and today stripped it all down to replace. Took old collapsed bearing out and replaced with new ones ( inner and outer ).
Drove it home and got about 15 miles and totally went again, this time even worse, basically if it was not for the spilt pin it would of been off.
God knows where the nut casing went either but this was on there.
I am going to strip it down again tomorrow and have a look, but i can`t for the life of me figure out what i did wrong, any ideas ?
Has anything like this happened to anyone before
Does anyone know the torque setting the hub nut should be torqued up to. Could i have over tightened this and made the bearing collapse ?
Any help from anyone would be appreciated
Cheers Kenno
Web Team
Don't bother with the ago old technique of "seeing if you can push the washer with a screwdriver, but without levering it" - its too inconsistent.
I assume you used good workshop technique?
As Paul_c said tighten it until there is 'no play' then bang that split pin and your done.
If the wheel wont spin freely its too tighten, also if it wobbles its not tight enough.
~Madferret
Mk1 1457cc 5door GX '83
Bert i replaced the full kit with the races aswell, removed the old ones and then tapped the new ones in. To be honest i thought the whole replacing all this was quite easy, but obviously i must of done something wrong.
I did have a problem with getting the old inner bearing race off though, had to chisel it as it was stuck onto the stub axle.
When the inner bearing is on, should this sit right back and touch the seal as i had quite a bit of gap here, but it would not go any further back.
Also thinking about it, if the nut was too tight the drum would not of moved would it as i did tighten it bit to much at 1st and it did not move then loosened off a bit and seemed fine.
When i put the wheel back on i had no play in it at all, where as the other side did have a little play (the bearing that is).
Chudd might take you up on that, i will take it off in the morning and see whats what with it, but as it is it won`t make it to yours without the wheel dropping off
~Madferret
It seems that the inner bearing is ok, can someone confirm off the picture that it should sit like that.
I now think i am going to have to change the stub axle as this looks to me like its knackered now from me driving it a few miles with the bearing like this.
Right just to confirm,
Races into the drum,
Inner bearing tapped on,
Then drum on,
Then outer bearing tapped into place,
Then washer on,
Then nipped up with hub nut,
Drum should still be able to move freely,
Is that about the run down of it, obviously loads of grease aswell.
Are rear tintop gti brakes the same as my late clipper cab, same drums and bearings
Cheers Mark
Cheers Mark
As you can probably guess i have never actually changed a rear bearing, or ever stripped the brakes down
Cheers Mark
Chudd is seeing if he has got one spare for me. I definatly over tightened this hub nut after speaking to Chudd on how it should be.
Live and learn though i guess
Cheers Mark
