Rear spring replace
(In Topic #72692)
Guest user
Rear spring replace
This Sunday I intend to replace the cracked rear springs on my Cabrio. Got the spring compressors but only a Haynes Mk2 manual. Does the Mk1 and Mk2 rear set up differ?
HELP!!!!
Guest user
If its a GTI make sure that when reassembling, the cut off part of the grey/white upper spring seat (you'll know what I mean) is in the outer position so there isn't a chance of it fouling on the tyre.
As crazy says, its a pretty straight forward job.
Cheers,
Ross
I used a spring compressor for caution before removing the cap. Takes about 30 minutes top each side.
Control functions:
