Rattling/ knocking over bumps and rough ground
(In Topic #123305)
I've got a really annoying rattling/knocking noise that I can't trace coming from the front of the car when going over rough ground or bumps- can anyone help me source it please?
I have replaced all this so far- springs, shocks, top mounts, steering rack and track rod ends and I'm running out of ideas. I've jacked the car up and can't see or feel anything that is loose- I did notice that the sub frame under the block wasn't attached at one point on each side (i.e. only 2 of the 4 bolts were in place) so I fitted the missing 2 today bolts but it has made zero difference.
Any ideas? :dontknow:
Cheers,
Meenrod
1991 Mk1 Golf GTI Cabriolet Sportline
Meenrod
just a guess .
start looking at all the rubber bits around the front
hope this helps
cheeers!
booze and boredom, the greatest mix
It's most commonly caused by worn wishbone bushes.
I'm guessing it's a sort of "clapping" sound over speed bumps, rough ground, potholes etc?
Is it easier replacing the whole wishbone rather than trying to get the bush out? Do new wishbones come with bushes?
Cheers,
Meenrod
Meenrod
hub nut
