questions
(In Topic #108098)
questions
bhp and mpg, cant be a bad thing. also is it possible that the power steering rack/setup from a cabby can be swapped into a tin top?.
Brakes - the 16V servo and master cylinder doesn't add any more braking power as such, since its still the same discs and pads. All it does it shortens the stroke (due to the bigger MC) and makes it less effort to press (due to the bigger servo). 256mm or 280mm discs would be more sensible - how much power is the 20vT you're going for? Keep ther rears drums, no value in upgrading to discs really.
TDI - a few people have done it but with the Mk1 Golf being a light car, doesn't really benefit from being diesel as much as a heavier car does. Basically when you tune the diesel to go faster, the power is delivered lower down which means there is in fact more torque, which overwhelms the tyres and you just spin the wheels more, rather than accelerating any quicker. Also its a costly option to go down. Sure, for a larger car such as the Mk4 it makes more sense.
Having said that, I'd be interested to hear of any high power diesels around, and welcome stats on 0-60 times and 1/4 mile run, to illustrate how it compares against the stock GTI or another engine conversion.
