Problem!?!?!? Knocking and pulls to the left Y?????
(In Topic #120057)
PROBLEM HAS JUST STARTED, I CAN ACCELERATE IN A STRAIGHT LINE WITH NO PROBLEM THE MINUITE I LET OFF THE GAS WITHIN SECOND THE WHEEL PULLS LIGHTLY TO THE LEFT AND A KNOCKING NOISE SOUNDS EVERY SO OFTEN, THIS HAPPENS EVERY TIME I LET OFF THE GASS AND LET IT FREE WHEEL AT SPEED.
AND ADVICE OR IDEARS??????
CHEERS IAN
CHEERS IAN
check your hub nuts on both sides.
i had something similar a while back. i tried loads of things before finding that the hub nut (on the opposite side to where i thought the knocking was coming from) was about half way un-done!
i think its a 32mm, big old socket.
ash x
ash x
bottom arm fixing bolts or a ball joint
KTML
noises
Bottom arm bushes,knackered bottom arm ball joint or track-rod end.If they are all old its a good idea to change them all,it will save on tyre waer in the short/long run! They are all cheap parts!Get tracking set too when replaced!
ash, did you find a solution to the problem, i am having the same troubles
Stay low, move fast
