Poly bushes
(In Topic #97852)
Poly bushes
Right im wanting to replace all the bushes on my gti, was thinking may as well replace the wishbones at the same time. What do i need apart from the bushes obviously and new wishbones to get the job done? ie nuts, bolts, brackets etc?
And also wishbones from GSF? anyone used these, fine or any problems?
Thanks in advance
'83 Mk1 Gti
'97 Mk3 Gti Daily hack
You'll need the ball joint as well but that's about it really - better if you can buy them with the bushes pressed in if possible
The kit is on the GSF website but isn't under the mounts section, it's in the suspension bit IIRC.
Cheers,
Gav
James
'83 Mk1 Gti
