Paddle gear shift?
(In Topic #123857)
Paddle gear shift?
Don't laugh.
The actual adding the flappy paddles would be the easy bit!
Was hoping that it had been done before but had a look and couldn't find one.
If you used actuators, will you hvae one doing the clutch too, or will you still need to press a clutch pedal to change gear? Or will your custom gearchange crunch the gears if you forget to press the pedal etc?
Member of the month GET YOUR SAY IN NOW
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86608&highlight=
