No rear brake query. Help please.
(In Topic #156560)
I've completely rebuilt my mk1. Including..
new mk2 16v master cylinder and servo (thread shortened).
new brake lines, refurbished g60 calipers and disks 280mm front.
mk1 standard drums on the back brand new,inc handbrake cable.
plumbed n correctly with t-piece for brake light switch.
Everything brand new.
I've bled the system many times. However the rear brakes are more or less non existent. Bleed nipple right way up etc.
i used the wife pump the pedal method and easy bleed method however. Stamp on the brakes and there's nothing there. The adjuster on the rear drum is at max after trying every setting. It seems (when I crack the rear bleed nipple open) no fluid drips from the bleed nipple if I open it,it takes a few second to drip.
air still in it?
do mk1 golf have a inline residual brake pressure valve? Mine came with brakes lines sooo rotten I couldn't tell. I removed the compensator and tried it all again but nothing.
Helpppppp please.
Last edit: by smudger
im also going to buy a wilwood 10lbs residual brake pressure valve in the morn.
Out of the whole complete resto the easiest bit has turned out to be the most frustrating.
