new installed clutch/box problem
(In Topic #127589)
With the old box/clutch, bite point was pretty high i.e. the pedal was almost fully up before the clutch engaged. The cable adjuster was almost fully screwed out and this gave an acceptable amount of free pedal travel.
The truck is driving fine with new box/clutch but I am concerned as the bite point is now much closer down to the floor, and there is far too much free travel in the pedal (3-4 inches!), this is with the cable adjuster fully screwed out.
Anyone have ideas what could be wrong?
Thanks guys.
I've now done about 10k miles on the clutch so no problems with it really, but the issue is starting to annoy me to the point where I might have to strip it down and attempt to find out what's going on… Thought maybe I hadn't described the problem well enough, so took a short video of what is going on with the clutch cable -
http://www.youtube.com/watch?v=znd8YbqTgs8
The cable adjuster is screwed all the way out. Screwing it in just increases the free travel on the pedal to the point where the clutch won't disengage.
Anyone?
Is it a genuine diesel with the clutch cable going around the back of the engine?
Were the rods that go thru the centre of the box the same between the two boxes?
Stick some washers under the adjuster at the gear box end to take up the slack?
Try a new cable?
ReleaseArm
TO Bearing
not sure how the above translates to a 4 speed box tho
There's a block of rubber and a couple of metal plates, and I'm sure a few other bits
all i have is the 2 metal plates, know where i can get this rubber part? sayint that i have tried spacing it out a bit with washers, which didnt work.
clutch pedal should be level with the brake pedal at rest
yep all the pedals sitting level
Is the bulkhead OK, it hasn't pulled thru?
Try a new cable?
bulkhead ok, has the repair plate fitted. It is a genuine diesel (it's actually a caddy :redfaced: ) and the cable in just now is the same as was used for the previous box (i have tried a new cable but wasn't much different - the old cable however is a gen vw one and seems to fit better so stuck with it for now).
I'm no expert but I think the problem is with the box/clutch. I can't be 100% certain that the pushrod going through the box were exactly the same (one may have worn more?) but the boxes were both identical 4 speed..
I have a theory about the new clutch.. if i remember correctly the circular disc part (the bit that's held in with a large circlip that the rod pushes on) was slightly different on the new clutch kit (LUK). The centre of this disc on the old clutch had a small raised bit in the centre, which i think was free to turn, where the rod pushed on to. The new clutch didn't have this. I remember looking into it at the time and all i could find was that some clutch kits have this and some don't, and that it was apparently not a big deal. However i'm thinking that since the new clutch doesn''t have this raised part then there could be an extra 5/6mm of space that the pushrod is moving into before coming into contact with the clutch?? And due to lever effect this could be translated into the 3-4inches of free pedal travel at the box??
Sorry i know it might be hard to follow my description… i will try to get some pics. I'm hoping there is a simpler explanation
Thanks.
33 is "1 set: attachment parts for clutch cable" and is part number 171 798 105
Spacing it out with washers MUST have moved the biting point, maybe you didn't use enough washers and couldn't sense any difference, but thinking through how the mechanism works, it must have done…
