nasty clunking from somewhere at the front...
(In Topic #81609)
A few weeks back I tightened up the back-lash screw on the steering rack and this made a slight improvement. I guessed the rest was down to worn bottom ball joints but I just had a good poke around with a pry-bar down there (with the car on a 4 post ramp and front wheels off the ground) and couldn't find anything loose. The only thing that had a bit of play were the driveshafts, but it's not like I'm getting worn driveshaft noises (like clicking on full lock.)
Anyone got any ideas what to check?
Most bits are new at the front, the wishbones are the only bits that haven't been treated to new bushes. Someone told me you can buy complete wishbones with ball joints - anyone know where's best to get them from?
Happens to mine . 40mm lowered , pot hole crash banghitting bumpstops
Check also the steering rack security and anti roll bar ends .
GSF then fit a bug pack poly bush set [also at GSF] .Ball joints are seperate items .
I guess if the rack is loose it'll be obvious - I'll get it on the 4-post ramp and give it a shake.
Any ideas on how best to check the lower ball joints - I tried a few things with a pry bar, but couldn't get any play.
Hi they are that cheap i would replace them if you think they may be causing the problem . I think they are under a Tenner from GSF .
Sure, they're cheap but you have to do all that messing around with drilling out the old studs and replacing with nuts and bolts to fit the new ones. I think you can get complete wishbones, but they're expensive and euro car parts are out of stock.
The car's not lowered - totally standard - surely it can't be the bumpstops?!? I'm pretty sure I'm not getting enough suspension travel whenever I hear it for that to be the case. New dampers as well.
I jacked it all up at the weekend and disconnected the struts at the top (to remove any tension from the springs.) I then got hold of the hubs in turn and shook, rived, pushed and pulled, but couldn't find signs of play anywhere!
have been told that anti roll bar bushes can be failing even if they look fine ??
i have been puzzled for ages and dont have the money to just start replacing
part after part un till i find the problem..
no helpfull tips i'm affraid but atleast you know there are other people struggling ot there too matey! " )
good luck and let me know what the problem was,
cheers, Rowan.
* steering rack still had play
* Steering column mounts/bearings loose
* The other ball joint (even though it had no play)
I decided to strip the whole front end down. I adjusted the steering rack back-lash again and replaced the other balljoint. I took the struts apart but wasn't able to get the inserts out (screw cap on too tight and I lost my special tool.) Still, I satisified myself that the inserts weren't loose by holding the bottom of the strut in a vice and riving the piston up and down. I also replaced the only original bushes - all 4 wishbone bushes (OE from VW). Just for good measure I got new wishbones too (Lemforder from euro car parts.)
Put it all back together and the noise has all but gone! Still slightly there, but might be my imagination or something's a bit loose in the dashboard. I've no idea what fixed it. I reckon it could have been the steering rack adjustment - I did it up as tight as I dared this time (go too tight and you get binding at the ends of the rack.)
As a side note - don't bother with ball joints from GSF! Even the most expensive FEBI-branded ones. The rubber boot on the one I replaced in 07 was found too be almost shot - surely would have failed next MOT. So I fitted VW ones on both sides! (Note the rubber on the 25yr old original one was still good!)
Dan
replaced top mounts, struts, shocks, wishbones were already poly bushed
had the car jacked up and been swinging on everything but nothing semmed loose
It's only when I go over bumpy ground and only on passenger side
<a href="signature2.jpg picture by jools182 - Photobucket"><img src="http://i88.photobucket.com/albums/k182/jools182/signature2.jpg" border="0" alt="Photobucket"></a>
Dan
Driveshafts are hitting the chassis when i go over potholes.
Seeing as it's not a constant thing I've learnt to avoid potholes. It's not a fix but I'm not going to mess around notching the chassis.
Jon.
