my brakes rattle !!!!!!!!!!!
(In Topic #116261)
By the way moved to running gear - correct section so hopefully more help will come along.
do they need fitting kits for the clipper calipers like they do on the 1.3s wit girling claipers?
<a><img></a>
<a><img></a>
Looking through looks like yours is a 1.8 clipper. Ive put a couple of pics below, one showing the anti rattle clips, which youve mentioned a couple of times and one showing the pads, just so you can check.
When you fitted the pads in the carriers where did they seem a very snug fit, ie very little movement. Cerrtainly was with myn.
If thats the case can only think the caliper bolts need checking or something else disturbed.
1988 1.8 carb Golf Clipper
its fixed!!!!
topmounts, bump stops etc.
