Mk1 Whining gearbox
(In Topic #83032)
Mk1 Whining gearbox
Whining noise
I wouldn't be able to tell you if it was your gearbox or not really but i
would also consider your wheel bearings.
I have got a whining noise comeing from my rear bearings so they are in
the prosess of being replaised.
Hope i have helped you in anyway possible.
Jamie
get i t rebuilt and you know it isnt going to go wrong for some time.
1983 mars red 1800GTi on ATS cups
G60'd, schrick cam, chipped, 70mm pulley, pace charge cooler, rolling road 182bhp 250Nm of torque, 14.50 quarter mile.
Had a whining gearbox to in my wifes caddy for over a year, … I wasn't going to spend money over a new gear box, because that would maybe give other problems. and gear change was no problem. the sound only came when pushing in the clutch pedal. and stopped when the box stopped turning, or when you lift your foot completely of the pedal.
Anyhow, it appeared to be a bearing that is accessible from the outside of the box, so was not expensive at all, the bearing is placed right behind the round green cap on the side of the box. haven't had time to find out exactly what it's use is, or what its name is (Patrick maybe
Should anybody require more info, just drop me a message and I'll be back.
Cheers,
I believe you asked Mars Red LA2A?
Mars Red it is !
Mars Red it is !
If its only a little noisy without gear or clutch problems just change the oil at the minute…..the drain is a 17 or 18 mm allen key, i got one but cant remember the size!!! (Hazzet do the correct tool) but you can buy a socket with the correct size from halfrauds, the drain is also the filling point, take the plug out on the narrow front part of the gbox and let it drain, then just refill with a decent hypoid gbox oil untill the level begins to flow out the hole again…..not an exact science i know but its all i have ever done on all my Gti`s and had no problems, you can also buy a slick 50 treatment or wynns do a gear lube aswell……..new oil on its own always helps though, makes the box more possitive, it might be whining as it dont have enough oil in now?
