Lower Balljoint difference
(In Topic #107925)
Hi
I went to replace the balljoint on the drivers side wish bone, The GSF part would not fit into the hub after many hours of trying.
Before I had replaced the passenger side balljoint with the same GSF part with no problems.
So I measured the Diameter of the ball joint and found it to be 15mm drivers side and 16mm passenger side
The left is driver and the right is passenger.
The picture above is the back of the hub, Does anyone know the correct part for this hub, and why there would be a difference?
Golf Gti 1.8 DX Mars Red
Golf Gt Tsi United Grey
1mm ? Why not just simple open up the lower ball joint holder with a suitable item . All hubs are the same on the MK1 , the clamp bolt can be tightened to such a degree that a new item will not fit unless you open it up using a suitable tool . This is common practice . Chisel , pri bar etc inserted will give sufficient leverage .
Hope this helps …………
Life Member
I did try the Pri bar and chisel also letting the car drop onto the wishbone with a block of wood underneath to try and force in it. It was very head wrecking.
My car is an 83 but maybe at some point in its life the hub was changed on the drivers side back to the old type, I didnt know this.
Do you think CrazyQuiff would carry this earlier part? Around lunch tommorow I will call in to my local gsf and see what other ball joints they have and I have my verniers with me.
Cheers Ed
Cheers Ed
