knock knock knock
(In Topic #79309)
knock knock knock
Hi
I just went for a lengthly drive and noticed really strong knocking from the underneath somewhere. It's hard to tell exactly. The engine runs perfect, gears great, brakes OK. The noise seems to decrease or disappear when breaking or accelerating. It is most noisy when coasting, (clutch in) or just slowing down without brake. I really didn't think I'd get home but I made it.
I read the post 'knock knock' but this seems a bit different. Any ideas would be great.
Con
Con
I had the same noise, turned out to be loose wheel bolts
i had the same noise and it turned out that my big ends had gone and the crankshaft was damaged!
ops:
hope it is something smaller than that mate!
Andrew
Andrew
does the noise seem to happen more if your on a bumpy surface i had the same sort of noise turned out to be the top mounts on my front shocks. there was about a 1cm gap between the rubbers and the upper plate on them.
centre box exhaust mounts maybe, had similar on a polo and it was that. more so under acceleration and braking,
rebuild in progress....
loose wheel bolts on left passenger wheel.
:dontknow: don't know why they were loose but I'm very glad.
noise gone. money still in pocket
thanks for the help
