is the camber on a 87 git cabby ajustable???
(In Topic #111506)
1987 gti cabby
Once you've done the camber you'll need to check/reset the tracking. Originally Golfs came with 1 adjustable and 1 fixed track rod, but replacements are always supplied as adjustables, so yours might now have 2. You loosen off both nuts (one is reverse threaded), turn the track rod to make it shorter or longer between the track rod end and the rack, then retighten.
You'll need a camber gauge and a tracking gauge, which aren't that costly but might want to simply leave it to a garage?
nice one
1987 gti cabby
