inner cv boot????
(In Topic #99489)
inner cv boot????
Clean up, remove CVJ (you'll need circlip pliers)
Pull off and replace boot
reassembly is a reversal of removal..
Tried hex bit in ratchet and tried allen key.
But it either slips or won't spin. Is there an easy way to stop the drive shaft spinning without the wheel on? or do I have to scramble about on the floor
drained all the oil as i thought about popping the driveshaft from the box side but there is a bolt within isn't there??? (someone confirm before i split the casing???)
spent ages on it about to get the sledge hammer out….
help….
oh and some one snapped one of the bolts before i owned it do i start crying now???
think i might have to go get more gas for the blow torch…..
all help gratefully received.
get the bigger hammer. it always makes things better…..
Highland Regional host
If your car is in the air (ie on axle stands) and you need to lock a wheel, put it in gear and put a trolley jack (or something else to jam it to not move) underneath the other side's wheel/tyre.
Trip to hal'frauds it is then.
How do I do this?
