inner cv boot????
(In Topic #99489)
inner cv boot????
how you change offside inner cv boot please any easy wy at all either?? have got new cv boot and bolts too go on just need too know any way of doing it. ta all
Unbolt driveshaft at gearbox flange (6x M8 12 spline bolts)
Clean up, remove CVJ (you'll need circlip pliers)
Pull off and replace boot
reassembly is a reversal of removal..
luvly jubbly thanks for that nice one ta
sounds so simple but can't get the bolts off the gearbox flange
Tried hex bit in ratchet and tried allen key.
But it either slips or won't spin. Is there an easy way to stop the drive shaft spinning without the wheel on? or do I have to scramble about on the floor
drained all the oil as i thought about popping the driveshaft from the box side but there is a bolt within isn't there??? (someone confirm before i split the casing???)
spent ages on it about to get the sledge hammer out….
help….
oh and some one snapped one of the bolts before i owned it do i start crying now???
think i might have to go get more gas for the blow torch…..
all help gratefully received.
help….
get the bigger hammer. it always makes things better…..
Highland Regional host
Some cars have female hex head bolts for the inner CVJ (ie its been swapped in the past) but it should be M8 12 spline as stated above. Obviously using the wrong tool, will not help the cause!
If your car is in the air (ie on axle stands) and you need to lock a wheel, put it in gear and put a trolley jack (or something else to jam it to not move) underneath the other side's wheel/tyre.
A good trick is if you have a long breaker bar you can jam this between the brake pedal and the seat, this provides enough brake pressure to stop the shafts turning.
female hex bolts sodding great………
Trip to hal'frauds it is then.
I have done this but you still can't remove the rubber boot?
How do I do this?
How do I do this?
